Specifies the authentication password (up to eight characters) or RSA Data Security, Inc. MD5 Message-Digest Algorithm key for one or all interfaces in a specific area or a virtual link.
| vlan-name | Specifies a VLAN name. |
| all | Specifies all VLANs |
| router-identifier | Specifies the router ID of the remote router. |
| area-identifier | Specifies an OSPF area. |
| encrypted | Indicates that the password (or key) is already encrypted (do not use this option). |
| simple-password | Specifies an authentication password (up to 8 ASCII characters). |
| md5_key_id | Specifies a RSA Data Security, Inc. MD5 Message-Digest Algorithm key, from 0-255. |
| md5_key | Specifies a numeric value from 0-65,536. Can also be alphanumeric, up to 26 characters. |
| none | Disables authentication. |
N/A.
The md5_key is a numeric value with the range 0 to 65,536 or alphanumeric. When the OSPF area is specified, authentication information is applied to all OSPF interfaces within the area.
The encrypted option is used by the switch when generating a configuration file and when parsing a switch-generated configuration file. Do not select the encrypted option in the CLI.
The following command configures RSA Data Security, Inc. MD5 Message-Digest Algorithm authentication on the VLAN subnet_26:
configure ospf vlan subnet_26 authentication md5 32 test
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
