Configures the timers for a virtual link.
| router-identifier | Specifies the router ID of the other end of the link. |
| area-identifier | Specifies an OSPF area. |
| retransmit-interval | Specifies the length of time that the router waits before retransmitting an LSA that is not acknowledged. The range is 1–3,600 seconds. |
| transit-delay | Specifies the length of time it takes to transmit an LSA packet over the interface. The range is 1–3,600 seconds. |
| hello-interval | Specifies the interval at which routers send hello packets. The range is 1–65,535 seconds. |
| dead-interval | Specifies the interval after which a neighboring router is declared down due to the fact that hello packets are no longer received from the neighbor. The range is 1–2,147,483,647 seconds. |
Configuring OSPF timers on a per-area basis is a shorthand for applying the timers and authentication to each VLAN in the area at the time of configuration. If you add more VLANs to the area, you must configure the timers and authentication for the new VLANs explicitly.
The following command sets the timers on the virtual link in area 0.0.0.2 and remote router ID 6.6.6.6:
configure ospf virtual-link 6.6.6.6 0.0.0.2 timer 10 1 20 200
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
