Configures the minimum number of seconds between Shortest Path First (SPF) recalculations.
| seconds | Specifies a time in seconds. The range is 0 to 300 seconds. |
3 seconds.
Not applicable.
The following command configures the minimum number of seconds between Shortest Path First (SPF) recalculations:
configure ospf spf-hold-time 6
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
