Displays the current sFlow configuration.
| configuration | Displays the sFlow configuration. |
N/A.
This command displays the sFlow configuration of your system.
Global Status—sFlow is globally enabled or disabled.
Polling interval—How often the hardware is polled for statistics, in seconds.
Sampling rate—Packets are sampled, on average, once for every rate-number of packets.
Maximum cpu sample limit—Maximum number of packets per second sampled before sample throttling takes effect.
Agent IP—IP address inserted into the sFlow data packets to identify the sFlow switch.
Collectors—To which IP address and port, and from which virtual router, the sFlow packets are sent.
Port Status—Enabled or disabled for statistics gathering.
Port Sample-rate—Shows the sampling rate configured for the port and the actual rate if CPU throttling has taken effect.
Port Subsampling factor—for details, see the command configure sflow max-cpu-sample-limit.
To display the sFlow configuration on your system, use the following command:
show sflow
The following is an example of the show sflow configuration command :
SFLOW Global Configuration
Global Status: enabled
Polling interval: 20
Sampling rate: 8192
Maximum cpu sample limit: 2000
SFLOW Configured Agent IP: 0.0.0.0
Operational Agent IP: 10.127.11.88
Collectors
SFLOW Port Configuration
Port Status Sample-rate Subsampling Sflow-type
Config / Actual factor Ingress / Egress
5:21 enabled 8192 / 8192 1 Disabled / Enabled
This command was first available in an ExtremeXOS 11.0.
