Displays sFlow hardware table utilization statistics.
| hardware-utilization | Specifies showing hardware table utilization statistics. |
| slot | Specifies selecting slots. |
| slot_num | Specifies which slots to show statistics for. |
| all | Specifies showing statistics for all slots. |
N/A.
This command displays sFlow hardware table utilization statistics for your system.
The following example shows sFlow hardware table utilization statistics.
# show sflow hardware-utilization
sFlow Hardware Table Utilization Statistics
Resource Type Current Maximum % Util.
MAC Entries 3 73727 0
Host Entries 4 73728 0
IPv4 Entries 0 73728 0
IPv6 Entries 2 36864 0
Long IPv6 Entries 0 2048 0
Total Routes 11 8192 0
IPv4 Neighbors 5 N/A N/A
IPv6 Neighbors 0 N/A N/A
IPv4 routes 3 N/A N/A
IPv6 routes 3 N/A N/A
ECMP Next Hops 2 1023 0
ACL Ingress Entries 42 10752 0
ACL Ingress Counters 0 233472 0
ACL Ingress Meters 0 12288 0
ACL Ingress Slices 0 12 0
ACL Egress Slices 0 4 0
Legend: N/A - Maximum not defined in published sFlow structure.
Also see IP usage in 'show iproute reserved-entries statistics'.
This command was first available in ExtremeXOS 22.5.
Ability to select slots in a stack was added in ExtremeXOS 22.6.
Legend explaining N/A entries was added in ExtremeXOS 30.1.
