Configures a VRRP VLAN to track port connectivity to a specified VLAN. When this VLAN is in the down state, this entry is considered to be failing.
| vlan_name |
Specifies the name of a VRRP VLAN. |
| vridval |
Specifies the VRID of the target VRRP instance. To display the configured VRRP router instances, enter the show vrrp command. |
| target_vlan_name |
Specifies the name of the VLAN to track. |
N/A.
Up to eight VLANs can be tracked.
Deleting a tracked VLAN does not constitute a failover event for the VRRP VLAN tracking it, and the tracking entry is deleted.
The following command enables VRRP VLAN vlan-1 to track port connectivity to VLAN vlan-2:
configure vrrp vlan vlan-1 vrid 1 add track-vlan vlan-2
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature, see the Switch Engine v33.1.1 Licensing Guide document.
