Creates a tracking entry for the specified IP address. The entry is tracked using pings to the IP address, sent at the specified frequency.
| vlan_name |
Specifies the name of a VRRP VLAN. |
| vrid vridval |
Specifies the VRID of the target VRRP instance. To display the configured VRRP router instances, enter the show vrrp command. |
| ipaddress |
Specifies the IPv4 or IPv6 address to be tracked. |
| frequency seconds |
Specifies the number of seconds between pings to the target IP address. The range is 1 to 600 seconds. |
| miss misses |
Specifies the number of misses allowed before this entry is considered to be failing. The range is 1 to 255 pings. |
| success successes | Sets how many ping successes are required for tracking success. Range is 1–255. (Default is 10 × misses.) |
If the number of successes is not specified, the default is ten times the number of misses specified.
Adding an entry with the same IP address as an existing entry causes the new values to overwrite the existing entry's frequency and miss number.
The following command enables ping tracking for the external gateway at 3.1.0.1, pinging every 3 seconds, and considering the gateway to be unreachable if no response is received to 5 consecutive pings:
configure vrrp vlan vlan-1 vrid 1 add track-ping 3.1.0.1 frequency 3 miss 5
The success option was added in ExtremeXOS 22.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature, see the Switch Engine v33.1.1 Licensing Guide document./ph "/>
