Deletes a dynamic ACL.
| dynamic_rule | Specifies the dynamic ACL name. |
N/A.
This command deletes a dynamic ACL rule. Before you delete a dynamic ACL, it must be removed from any interfaces it is applied to. Use the configure access-list delete command to remove the ACL from an interface.
The following command deletes the dynamic ACL icmp-echo:
delete access-list icmp-echo
This command was first available in ExtremeXOS 11.3.
