Limits number of simultaneous CLI sessions on the switch.
| num-of-sessions | Specifies the maximum number of concurrent sessions permitted. The range is 1 to 16. |
The default is eight sessions.
The value must be greater than 0; the range is 1 to 16.
The following command limits the number of simultaneous CLI sessions to ten:
configure cli max-sessions 10
