Establishes the maximum number of failed logins permitted before the session is terminated.
| num-of-logins | Specifies the maximum number of failed logins permitted; the range is 1 to 10. |
The default is three logins.
The value must be greater than 0; the range is 1 to 10.
The following command sets the maximum number of failed logins to five:
configure cli max-failed-logins 5
