This command configures the size of the historical list (journal) of the most recently executed CLI commands.
| journal | List of the most recently executed CLI commands. |
| size size | Configures the size (number) of remembered commands. Range is 50 to 200 (default = 100). |
One hundred commands are preserved in the journal by default.
The journal retains as many as 200 of the most recently executed commands along with the timestamp and user name. Commands are saved even after logging off, rebooting, or switch crashes.
To view the journal, use the show cli journal command.
The following example sets the journal size to 150:
configure cli journal size 150
This command was first available in ExtremeXOS 22.1.
