Configure Internet Protocol Security (IPsec) with a manual key to provide authentication on OSPFv3 virtual-links.
| ospfv3 | Specifies OSPFv3 virtual-link. |
| virtual-link | OSPFv3 virtual link. |
| routerid | OSPFv3 router ID. |
| router-identifier | Specifies the router identifier of the advertising router. |
| area | OSPFv3 area. |
| area-identifier | Specifies an OSPFv3 area, a four-byte, dotted decimal number. |
| authentication | Specifies interface authentication. |
| none | Specifies no authentication (default). |
| keychain | Specifies the authentication method is keychain. |
| keychain-name | Specifies the keychain name. |
| ipsec spi | Specifies the authentication type is IPsec Encapsulating Security Payload (ESP) with manual key. |
| spi | Specifies Security Parameter Index value. Range is 256-4294967295. |
| esp-auth-algorithm | Specifies the ESP Authentication algorithm. |
| algorithm |
Specifies the authentication algorithm. Supported authentication algorithms are hmac-sha-1 and hmac-sha-256. |
| key | Specifies the authentication key, |
| key-string |
Specifies the key string in clear text. Both the ASCII string and hexadecimal string are supported, and hexadecimal string must begin with “0x”. |
| encrypted | Specifies that the key string is in encrypted format. |
| encrypted-key-string |
Specifies the encrypted key string. The encrypted key string must be enclosed in double quotes. |
If not specified, no authentication is applied.
When configuring IPsec with a manual key on an OSPFv3 virtual link, the exact same IPsec parameters (SPI, algorithm and key-string) must be specified on all routers connected to both sides of the virtual link.
To configure OSPFv3 VLAN authentication, run the command configure ospfv3 [{vlan} vlan-name | {tunnel} tunnel-name] authentication [none |ipsec spi spi esp-auth-algorithm algorithm key [key-string | encrypted encrypted-key-string].
The following example for virtual-link "5.5.5.5 0.0.0.2" applies authentication type IPsec with SPI "1001" and algorithm "hmac-sha-1" with key "mykey":
# configure ospfv3 virtual-link 5.5.5.5 0.0.0.2 authentication ipsec spi 1001 esp-auth-algorithm hmac-sha-1 key mykey
This command was first available in ExtremeXOS 31.2.
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
