Configure Authentication Trailer with a manual key to provide authentication on OSPFv3 virtual-links.
| ospfv3 | Specifies OSPFv3 virtual-link. |
| virtual-link | OSPFv3 virtual link. |
| routerid | OSPFv3 router ID. |
| router-identifier | Specifies the router identifier of the advertising router. |
| area | OSPFv3 area. |
| area-identifier | Specifies an OSPFv3 area, a four-byte, dotted decimal number. |
| authentication | Specifies interface authentication. |
| keychain | Specifies the set of authentication keys. |
| keychain-name | Specifies the keychain name. |
| none | Specifies no authentication (default). |
If not specified, no authentication is applied.
Users can only add keychains that are already present on the system. Keychains can be created using this command create keychain keychain_name .
The following example for virtual-link with a router id of 10.1.1.3 and an area identifier of 1.1.1.1:
# configure ospfv3 virtual-link 10.1.1.3 area 1.1.1.1 authentication keychain ospfv3-keys1
This command was first available in ExtremeXOS 31.3.
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
