Removes one or all IP destination addresses for forwarding BOOTP packets.
ipv4 | DHCPv4 BOOTP Relay service (default). |
ipv6 | DHCPv6 BOOTP relay service. |
ip_address | Specifies an IP address. |
all | Specifies all IP address entries. |
vrid | Specifies a VR or VRF name. |
If you do not specify a VR, the current VR context is used.
If you do not specify DHCPv4 or v6 BOOTP Relay service, DHCPv4 is used.
None.
The following command removes the destination address:
configure bootprelay delete 123.45.67.8
