configure bootprelay dhcp-agent information check
Description
Enables the DHCP relay agent option (option 82) checking.
Syntax Description
Default
Disabled.
Usage Guidelines
In some instances, a DHCP server may not properly handle a DHCP request packet containing a relay agent option. Use this command to prevent DHCP reply packets with invalid or missing relay agent options from being forwarded to the client.
To disable this check, use the following command:
unconfigure bootprelay dhcp-agent information check
The following command configures the DHCP relay agent option check:
This command was first available in ExtremeXOS 11.1.
Platform Availability
