Disables a peer group and with respect to the next-hop of routes advertised to EBGP peers.
| peer-group-name | Specifies a peer group. |
| 12vpn-evpn | Specifies L2VPN EVPN address-family type. |
| next-hop-unchanged | Enables preserving the BGP next-hop when routes are advertised to EBGP peers (default is disabled). |
Default is that next-hop-unchanged is disabled.
This command disables overriding the specification behavior with respect to the next-hop of routes advertised to EBGP peers. Specifically, disabling with this command does not maintain the BGP next-hop for routes advertised to EBGP peers.
The following command disables next-hop unchanged for the BGP peer group pg2 :
disable bgp peer-group pg2 l2vpn-evpn next-hop-unchanged
This command was first available in ExtremeXOS 31.4.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
