This command disables an address family or the route-refresh capability for a peer group.
| peer-group-name | Specifies a peer group. |
| ipv4-unicast | Specifies the IPv4 unicast address family. |
| ipv4-multicast | Specifies an IPv4 multicast address family. |
| ipv6-unicast | Specifies the IPv6 unicast address family. |
| ipv6-multicast | Specifies an IPv6 multicast address family. |
| vpnv4 | Specifies the VPNv4 address family for Layer 3 VPN support. |
| route-refresh | Specifies ROUTE-REFRESH message capabilities. |
All capabilities are enabled for IPv4 peer groups by default.
Only the route refresh capability is enabled for peer groups by default.
This command applies to the current VR or VRF context.
To inter-operate with Cisco routers for BGP graceful restart, you must enable IPv4 unicast address capability.
The following command disables the route-refresh feature for the peer group outer:
disable bgp peer-group outer route-refresh
The following command disables the VPNv4 address family for a peer group:
disable bgp peer-group backbone capability vpnv4
Support for IPv6 was added in ExtremeXOS 12.6 BGP.
Support for Layer 3 VPNs was added in ExtremeXOS 15.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
