Enables LDP for the specified MPLS configured VLANs.
| vlan | Enables LDP for one or more specific VLANs. |
| vlan_name | Enables LDP on the specified VLAN. |
| vlan all | Enables LDP for all VLANs that have been added to MPLS. |
Disabled.
When LDP is enabled, LDP attempts to establish peer sessions with neighboring routers on the enabled VLAN. Once a peer session is established, LDP advertises labels for local IP interfaces and for routes learned from other neighboring routers. By default, LDP is disabled for all VLANs that have been added to MPLS. Specifying the optional all keyword enables LDP for all MPLS configured VLANs.
The following command enables LDP for all VLANs that have been added to MPLS:
enable mpls ldp vlan all
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
