enable mpls php
When enabled, PHP is requested on all LSPs advertised over that VLAN for which the switch is the egress LSR.
enable mpls php [{vlan} vlan_name | vlan all]
Description
Enables penultimate hop popping (PHP) on the specified VLAN.
Syntax Description
vlan Enables PHP for one or more specific VLANs.
vlan_name Enables PHP on the specified VLAN.
vlan all Enables PHP for all VLANs that have been added to MPLS.
Default
Disabled.
Usage Guidelines
Penultimate hop popping is requested by assigning the Implicit Null Label in an advertised mapping. Extreme's MPLS implementation always performs penultimate hop popping when requested to do so by a peer LSR. When the all VLANs option is selected, PHP is enabled on all configured VLANs that have been added to MPLS.
The following command enables penultimate hop popping (PHP) on the specified VLAN:
enable mpls php vlan vlan1
This command was first available in ExtremeXOS 11.6.
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
