unconfigure ip-security dhcp-snooping information option
Description
Disables the DHCP relay agent option (option 82).
Syntax Description
Default
N/A.
Usage Guidelines
This command disables the DHCP relay agent option (option 82), which is inserted into client-originated DHCP packets before they are forwarded to the server.
Platform Availability
