This command allows you to delete one or all RMEPs from a group.
mepid |
Specifies the MEP ID of the remote MEP being created. The range is 1 to 8191. |
N/A.
Use this command to delete one or all RMEPs from a group.
configure cfm group “eapsCfmGroup” delete rmep 2
This command was first available in ExtremeXOS 15.2.
