Adds a CFM domain and association to a CFM segment.
| segment_name | An alpha numeric string identifying the segment name. |
| domain_name | Specifies the IEEE 802.1ag maintenance domain. |
| association_name | IEEE 802.1ag or ITU-T Y.1731 association name. |
N/A.
Use this command to add a CFM domain and an association to a CFM segment. It is used to enable DMM/DMR in the association that is configured in the CFM domain.
The following command adds the domain cfm3 and the association as3 to the segment s2.
configure cfm segment s2 add domain cfm3 association as3
To delete the domain and/or association, use the command, configure cfm segment delete domain association.
This command was first available in ExtremeXOS 12.3.
