This is a script command and operates only in scripts when scripting is enabled with the following command: enable cli scripting {permanent}.
Causes the WHILE construct to be terminated.
N/A.
The ENDWHILE command must be used after a corresponding WHILE _expression DOstatement(s) command.
You can insert comments by using a number sign (#). CLI scripting must be enabled to use this command.
This example creates 10 VLANs, named x1 to x10:
set var x 1
WHILE ($x <= 10) DO
create vlan v$x
set var x ($x + 1)
ENDWHILE
This command was first available in ExtremeXOS 11.6.
