This is a script command and operates only in scripts when scripting is enabled with the following command: enable cli scripting {permanent}.
Causes the IF construct to be terminated.
N/A.
The ENDIF command should be used after the IF _expression THEN statement(s) command.
You can insert comments by using a number sign (#). CLI scripting must be enabled to use this command.
The following example executes the show switch command if the value of the variable is greater than 2 and execute the show vlan command otherwise:
IF ($x > 2) THEN
show switch
ELSE
show vlan
ENDIF
This command was first available in ExtremeXOS 11.6.
