Configures a SNMP VPN identifier for traps from the specified VLPLS.
| vpls_name | Specifies the VPLS for which you are configuring the identification string. |
| identifier | Specifies a text string to identify the VPLS in SNMP traps. |
N/A.
None.
The following command configures the identifier vpls1trap for SNMP VPN traps on VPLS vpls1:
configure vpls vpls1 snmp-vpn-identifier vpls1trap
This command was first available in ExtremeXOS 12.4.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
