configure vr add ports
configure vr vr-name add ports port_list
Description
Assigns a list of ports to the specified VR.
Syntax Description
vr-name
Specifies the name of the
VR. |
port_list
Specifies the ports to add to
the VR. |
Default
By default, all ports are assigned to VR-Default.
Usage Guidelines
When a new VR is created, by default, no ports are assigned, no
VLAN interface is created, and no support for any
routing protocols is added. Use this command to assign ports to a VR. Since all
ports are initially assigned to VR-Default, you might need to delete the desired
ports first from the VR where they reside before you add them to the desired VR.
If you plan to assign VR ports to a VLAN, be aware
that the ports that you add to a VLAN and the VLAN itself cannot
be explicitly assigned to different VRs. When multiple VRs are defined, consider
the following guidelines while adding ports to a VR:
- A VLAN can belong (either through explicit or implicit
assignment) to only one VR.
- If a VLAN is not explicitly assigned to a VR, then the
ports added to the VLAN must be explicitly assigned to a single VR.
- If a VLAN is explicitly assigned to a VR, then the ports
added to the VLAN must be explicitly assigned to the same VR or to no
VR.
- If a port is added to VLANs that are explicitly assigned
to different VRs, the port must be explicitly assigned to no VR.
The following example adds all the ports on slot 2 to the VR
"vr-acme":
configure vr vr-acme add ports 2:*
This command was
first available in ExtremeXOS 11.0.
Platform Availability
This command is available on all Universal switches supported in
this document.
