Enables or disables Web server target(s).
| target | wSpecifies the configured target. |
By default, the target Web server is not enabled for xml-notifications. You have to explicitly enable it, and the display value is “no.”
Use the enable option to enable Web server target(s) in order to receive events from ExtremeXOS modules and to send out events to the targeted Web server(s).
Use the disable option to disable the Web server target(s).
The following command enables all of the configured targets:
enable xml-notification all
This command was first available in ExtremeXOS 12.4.
