Configures the default EAPOL version sent in transmitted packets for network login.
eapol-version | Specifies the EAPOL version. Choices are "v1" or "v2". |
The default is "v1".
Although the ExtremeXOS software supports EAPOL version 2, some clients do not yet accept the version 2 EAPOL packets. The packet format for the two versions is the same.
The following command changes the EAPOL version to 2:
configure netlogin dot1x eapol-transmit-version v2
This command was first available in ExtremeXOS 11.1.
