Configure the ports that are to be hijacked and redirected for HTTP or HTTPS traffic.
tcp_port | Specifies the port to be hijacked. |
N/A.
This command allows you to unconfigure the ports that will be hijacked and redirected for HTTP or HTTPS traffic.
