Removes a trusted CA certificate or OCSP response signature CA certificate from the switch.
| trusted-ca |
Specifies trusted CA certificates. Removes the CA certificate file(s) from folder/config/ssl/trusted_ca_certs/. |
| ocsp-signature-ca |
Specifies OCSP signature CA certificates. Removes the signature CA file(s) from folder /config/ssl/signature_ca_certs/. |
| file_name | Specifies a single CA certificate file for removal. |
| all | Specifies all CA certificate files for removal. |
None.
The following example removes all trusted CA certificates from the switch:
unconfigure ssl certificate trusted-ca all
This command was first available in ExtremeXOS 22.1.
