This command resets most stacking parameters to the default or unconfigured values.
| node_address |
Specifies the MAC address of a node in the stack. To view the MAC addresses for all nodes in a stack, enter the show stacking command. |
| slot_number |
Specifies the slot number of the target node. To view the slot numbers, enter the show stacking command. |
N/A.
Run this command from any node. If you do not specify a target node, the stacking parameters on all nodes are reset.
| Configuration Item | Takes Effect | Default Value |
Stacking Mode |
At boot time |
Disabled |
Slot Number |
At boot time |
1 |
Master-Capable |
At boot time |
Yes |
License Restriction |
At boot time |
Not Configured |
Priority |
At next master election |
Automatic |
Alternate IP Address |
Immediately |
Not Configured |
Stack MAC |
At boot time |
Not Configured |
configure stacking-support
To unconfigure the stacking parameters of all nodes in the stack topology:
unconfigure stacking
This command was first available in ExtremeXOS 12.0.
This command is available with all licenses and platforms that support the SummitStack feature. For information about which licenses and platforms support the SummitStack feature, see the Switch Engine v33.1.1 Licensing Guide document.
