Creates a DHCP binding.
| ip_address | Specifies the IP address for the DHCP binding. |
| mac_address | Specifies the MAC address for the DHCP binding. |
| dynamic | Configuration options for dynamically created VLANs. |
| vlan_id | VLAN ID tag between 1 and 4,094. |
| vlan_name | Specifies the name of the VLAN for the DHCP binding. |
| server_port | Specifies the server port for the DHCP binding. |
| client_port | Specifies the client port for the DHCP binding. |
| seconds | Specifies the number of seconds for the lease. |
N/A.
This commands allows you to add a DHCP binding in order to re-create the bindings after reboot and to allow IP Security features to work with clients having static IP addresses.
Setting the lease-time to 0 causes the DHCP binding to be static; in other words, it is not aged-out if no DHCP renew occurs. This is for use with clients using static IP addresses.
Dynamic VLAN and VLAN ID options added in ExtremeXOS 30.2.
