Enables the use of the specified Universal Port profile on the switch.
| profile-name | Specifies the UPM profile to be enabled. |
A UPM profile is enabled by default.
The following command enables a UPM profile called example on the switch:
enable upm profile example
This command was first available in ExtremeXOS 11.6.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.1.1 Licensing Guide document.
