Enables a VXLAN remote endpoint.
virtual-network | Virtual overlay network. |
remote-endpoint | Remote tunnel endpoint information. |
vxlan | VXLAN virtual networks remote endpoint. |
ipaddress | Specifies an IP address of a remote endpoint. |
ipaddress | Specifies the IP address of the desired remote endpoint. |
vr | Specifies a VR/VRF instance the remote endpoint is associated with. |
vr_name | Specifies the desired existing VR/VRF instance the remote endpoint is associated with. Default is VR-Default. |
all | Specifies all remote tunnel endpoints. |
If a VR is not specified, VR-Default is the VR.
Extreme Loop Recognition Protocol (ELRP) detects loops across VXLAN tunnels. If a loop is detected across the tunnel, ELRP takes down the VXLAN remote endpoint. You can use this command to re-enable the remote endpoint.
The following example enables the remote endpoint at 100.1.1.1 on VR-Default (not specified, command default):
# enable virtual-network remote-endpoint vxlan ipaddress 100.1.1.1
This command was first available in ExtremeXOS 22.4.
This command is available on all Universal switches and stacks supported in this document.
