Manually enables ports that have been disabled due to excessive link-flapping.
| ports | Physical ports. |
| port_list | List of ports that you want to enable that were disabled due to excessive link flapping. |
| all | Enables all ports in the system that were disabled due to excessive link flapping. |
| status | Enable ports currently in disabled state due to excessive link flapping. |
N/A
Ports that have been disabled due to excessive link flapping cannot be enabled using the enable port command. They must be enabled using the clear ports link-flap-detection status command.
The following example re-enables all ports on the switch that were disabled due to excessive link flapping:
clear ports all link-flap-detection status
This command was first available in ExtremeXOS 22.1.
