Use this command to re-enable a VLAN that you previously disabled.
| vlan_name | Specifies the VLAN you want to enable. |
| vlan_list | Specifies the VLAN list of IDs you want to enable. |
Enabled.
This command allows you to administratively enable specified VLANs that you previously disabled.
The following example enables the VLAN named "accounting":
enable vlan accounting
This command was first available in ExtremeXOS 11.4.
The vlan_list option was added in ExtremeXOS 16.1.
