Enables a VRF.
This command does not affect virtual routers.| vrf-name | Specifies the name of the VR or VRF instance. |
Enabled.
This command is used to administratively enable or disable a VRF. The VRF specific commands are still accepted and retained by the switch. This configuration has an operational impact on the VRF.
The following example enables VRF "vrf1":
enable virtual-router vrf1
This command was first available in ExtremeXOS 12.5.
