Controls whether the given VLAN ID may be advertised in MVRP messages transmitted on the given set of ports.
| mvrp | Multiple VLAN Registration Protocol. |
| tag | The 802.1Q VLAN ID. |
| transmit | When enabled, MVRP message are sent on the ports. |
| on | Transmission of MVRP messages are enabled on the port(s) for the given tag. |
| off | Transmission of the MVRP messages are disabled on the port(s) for the given tag. |
Transmit on.
Use this command to control whether the given VLAN ID may be advertised in MVRP messages transmitted on the given set of ports.
The following command configures transmit off for VLAN ID 100 on all MVRP ports:
configure mvrp tag 100 ports all transmit off
This command was first available in ExtremeXOS 15.3.
