Enables or disables the dynamic VLAN creation feature of MVRP.
| mvrp | Multiple VLAN Registration Protocol. |
| auto-creation | When enabled, results in VLANs added dynamically on the switch through MVRP. |
| on | Enable auto-creation. |
| off | Disable auto-creation. |
Enabled.
Use this command to enable or disable the dynamic VLAN creation of MVRP. By default, auto-creation is enabled. If disabled, the switch may participate in the MVRP protocol, and advertised static VLANs, but will not dynamically create VLANs.
The following command enables MVRP VLAN auto creation:
configure mvrp vlan auto-creation on
This command was first available in ExtremeXOS 15.3.
