This command is a global system setting. If global registration is forbidden, ports cannot be added to any VLAN dynamically.
| mvrp | Multiple VLAN Registration Protocol. |
| vlan | VLAN. |
| registration | Whether all ports can be added to new dynamic VLANs. This can be overridden by static port addition to VLAN. |
| forbidden | Ports cannot be added dynamically to the VLAN. This can be overridden by static port addition. |
| normal | Ports can be added dynamically to the VLAN (default). |
Normal.
Use this command to set global registration. If global registration is forbidden, ports cannot be added to any VLAN dynamically.
configure mvrp vlan registration normal
This command was first available in ExtremeXOS 15.3.
The registration keyword was first available in ExtremeXOS 15.3.2.
