Clears and initializes the network login sessions on a VLAN port.
| port_list | Specifies the ports to clear. |
None.
Clear the states of every MAC learned on this VLAN port and put the port back to unauthenticated state. The port will be moved to its original VLAN if configured in campus mode.
The following command clears the Network Login state of port 2:9:
clear netlogin state port 2:9
This command was first available in ExtremeXOS 11.1.
