Lets you configure network login aging.
minutes | Specifies the aging time in minutes. |
The default value is 5.
Use this command to configure the aging time for network login. The aging time is the time after which learned clients that failed authentication or did not attempt to authenticate are removed from the system. This prevents the switch from keeping all clients ever seen on a network-login-enabled port.
The range can be from 0 to 3000, where 0 indicates no age out.
The following command specifies an aging time of 15 minutes:
configure netlogin agingtime 15
This command was first available in ExtremeXOS 11.1.
