Configures the minimum number of seconds between Shortest Path First (SPF) recalculations.
| spf-hold-time | SPF hold time. |
| seconds | Specifies a time in seconds. The range is 0 to 300 seconds. |
3 seconds.
Setting the interval too high will force OSPFv3 to run SPF calculations less frequently. This will reduce the CPU load, but will cause delay in routes getting updated in the IPv6 routing table. Setting the interval too low will decreases the interval between SPF calculations, but will increase the processing load on CPU.
The following command configures the minimum number of seconds between Shortest Path First (SPF) recalculations:
configure ospfv3 spf-hold-time 6
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
