This command disables peer-group capability for a peer group on a Layer 3 VPN.
| remoteaddr | Specifies the IPv4 address of a BGP neighbor. |
| vpnv4 | Specifies the VPNv4 address family for Layer 3 VPN support. |
| community | Disables peer-group capability for communities. |
| ext-community | Disables peer-group capability for extended communities. |
| send | Disables peer-group capability filter list send capability. |
| receive | Disables peer-group capability filter list receive capability. |
| both | Disables peer-group capability filter list send and receive capability. |
Disabled.
If the direction is not specified, the both option applies.
Enter this command multiple times to configure the address family, type, and direction attributes.
By specifying the address-family, type and direction in multiple commands, you can better control the actual ORF capabilities sent to a peer. In the case where a particular address-family is explicitly disabled for a peering, the ORF capability configuration for that address-family is ignored and not sent.
ORF capabilities can only be enabled for IPv4 neighbors, and only for IPv4 address families. If configured for IPv6 neighbors or address-families the command is rejected with the following error message:
Outbound-route-filtering not supported for IPv6 neighbors
or
Outbound-route-filtering not supported for address family <addr_family>
The following command disables the peer-group capability feature for a Layer 3 VPN peer group:
disable bgp peer-group vpn capability address-family vpnv4
This command was first available in ExtremeXOS 15.1.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature,see the Switch Engine v33.1.1 Licensing Guide document.
