Displays one or all of the VM entries in the local VM database.
mac |
Specifies the MAC address of a VM database entry that you want to display. |
N/A.
If you do not enter a MAC address with this command, the command displays all entries in the local VM database.
The following command displays the local database VMs:
# show vm-tracking local-vm
MAC Address IP Address Type Value
00:00:00:00:00:21 VM
VLAN Tag 100
VR Name VR-Default
VPP vpp1
Number of Local VMs: 1
This command was first available in ExtremeXOS 12.5.
