Displays the XNV feature configuration and the authenticated VM information.
N/A.
None.
The following command displays the XNV configuration and the authenticated VMs:
* Switch.51 # sh vm-tracking
VM Tracking Global Configuration
VM Tracking : Enabled
VM Tracking authentication order: nms vm-map local
VM Tracking nms reauth period : 0 (Re-authentication disabled)
VM Tracking blackhole policy : none
Port : 1:20
VM TRACKING : ENABLED
Flags
MAC APC IP Address Type Value
00:00:00:00:00:11 LBI 255.255.255.255 VM
VPP lvpp1
IEP
EEP
00:00:00:00:00:12 --- VM
VPP
IEP
EEP
00:00:00:00:00:13 V--- 30.30.30.30 VM VMware-VM#2
VPP nvpp1
IEP a1.pol
EEP a2.pol
Flags :
(A)uthenticated : L - Local, N - NMS, V - VMMAP
(P)olicy Applied : B - All Ingress and Egress, E - All Egress, I - All Ingress
(C)counter Installed: B - Both Ingress and Egress, E - Egress, I - Ingress
Type :
IEP - Ingress Error Policies
EEP - Egress Error Policies
Number of Network VMs Authenticated: 1
Number of Local VMs Authenticated : 1
Number of VMs Authenticated : 2
This command was first available in ExtremeXOS 12.5.
