A Universal Port user-authenticate configuration requires specific components:
An Extreme Networks switch, which might need to include PoE support.
RADIUS server for user authentication and VSA transmission.
Supplicants that support the authentication method you select. LLDP support is recommended, but is optional when MAC address authentication is used.
To support supplicant configuration, you might consider adding a DHCP server to your network. For VoIP applications, you can use a TFTP server and a call server to provide for additional supplicant configuration.Use the following procedure to configure Universal Port for user login:
