After you finish the web-based network login configuration as described in Web-Based Network Login Configuration Example, complete the dynamic VLAN configuration by:
Do not enable network login on uplink ports. If you specify an uplink port with network login enabled, the configuration fails and the switch displays an error message.Whether you have MAC-based, web-based, or 802.1X authentication, you use the same two commands to configure dynamic VLANs on the switch.
configure netlogin dynamic-vlan uplink ports 2:1-2:2 configure netlogin dynamic-vlan enable
