When an switch receives Fabric Attach element TLVs on two or more ports that
have same System-Id, same SMLT-Id, and have a Connection Type of SMLT, it automatically
creates a LAG consisting of those ports. These LAGs:
- Do not persist after a reboot—after a reboot, TLVs must be received again to
re-form the LAG.
- Do not require receipt of LACP PDUs—LACP PDUs are not sent.
- Require at least two ports to form the LAG—if a port is removed from the LAG,
and the exiting LAG goes down to one port, it is torn down. When a LAG is
initially created with two ports, the lowest numbered port is chosen as the
master port of the LAG. If there are three or more ports on the LAG, and the
port is not the master port, it is simply removed from the LAG. If it is the
master port, the lag is torn down, and then re-created with the lowest port
number of the remaining ports as the master port.
- Are supported in stacks—the dynamic LAG is checkpointed to support failover,
etc.
A port is removed from a LAG under following circumstances:
- Port is administratively
disabled—if port is later administratively enabled, it will not automatically be
re-added to the LAG, it will take a receipt of a matching TLV.
- TLV with Connection Type other
than MLT is received.
- TLV with a System-ID that is
different from the one when the LAG was created is received.
- TLV with a SMLT-ID that is
The last three situations
indicate that you are not connected to same Fabric Attach server, or the same LAG on
a Fabric Attach server, which are not valid scenarios.
MLAG with Fabric
Attach Automatic LAG is not supported in ExtremeXOS 31.1 and later. Do not enable
MLAGs on ports where automatically created LAGs will be created.
To see a configuration example, see Fabric Attach Automatic LAG Configuration Example.
