configure radius netlogin keep-alive
configure radius netlogin keep-alive [ on | off]
Description
Configures the keep alive function for RADIUS servers using Network Login.
Syntax Description
keep-alive Specifies keep alive to test RADIUS server reachability.
onSpecifies to enable keep alive. Single success shows at least one server is reachable. Single failure shows no server is reachable.
offSpecifies to disable keep alive (Default).
Default
Off.
Usage Guidelines
This command configures the keep alive function for Network Login RADIUS servers. This enables sharing the Netlogin RADIUS server reachability status module.
When you enable this command, AAA sends an Access-Request using the RADIUS state machine subsystem in AAA the module and sets a dispatcher callback to repeat it for the configured keep alive interval. The following behavior scenarios exist when this command is configured:
Tip
Tip
The RADIUS server timeout configured using the configure radius netlogin timeout command should be less than the RADIUS keep-alive interval configured.
The Netlogin session timeout sent using the RADIUS attribute should be greater than the Netlogin keep-alive interval.
The following command configures keep alive for RADIUS Netlogin:
configure radius netlogin keep-alive on
This command was first available in Version 33.2.1.
Platform Availability
This command is available on all Universal platforms.
